CAD (Geometry) Formats for Export
The geometry can be exported to a number of industry-standard CAD formats.
The following CAD formats are supported for export:
Formats | File Format |
ACIS | .sat |
CATIA V4 | .model, .session, .exp |
CATIA V5 | .CATPart, .CATProduct, .CATShape |
IGES | .iges, .igs |
Parasolid | .x_t, .x_b |
STEP | .STEP, .stp |
Scaling is often the source of many importing errors when translating between CAD file formats (ACIS, CATIA, IGES, Pro Engineer, STEP, Unigraphics / NX, Parasolid).
CADFEKO does not perform any scaling during the export (scaling could cause tolerance errors during the subsequent import process). Change the scaling by modifying the CADFEKO model unit or model extents. If a model does not import as expected, change the scaling to import the geometry correctly.
