SpaceMouse devices
EDEM provides extended support for SpaceBall or SpaceMouse devices from 3Dconnexion.
Before running EDEM, ensure that the current drivers for your
device are installed. EDEM will automatically detect and
enable the use of the SpaceMouse once the device is connected and working properly. The
'6 degrees-of-freedom' input on the SpaceMouse devices do not require any special
configuration before being used within EDEM. However, you
can use the Mouse 3D Configuration control panel to adjust the device's sensitivity and
learn how the axes respond to input.
