The first step in setting up a calibration run is to load in a prototype EDEM deck. The deck should be configured so that they can be executed
from the command line.
To load a deck:
In the Load Deck page, which is the first page in
EDEMCal, specify the following details:
For
Specify
Locate deck to use
Specify the path to the EDEM
deck. The .dem file associated with the
EDEM deck must be used for
EDEMCal. This can be entered
or pasted into the field or located using Windows Explorer
by clicking the .... icon to
navigate to the deck and selecting
Open. This will populate the box
with the path to the .dem file.
Additional Files
Select any additional files required to run the
simulation from the command line. When importing multiple
additional files, highlight multiple files using File
Explorer and then add the files. Examples of additional
files include coupling scripts, preference files, and API
.dll or .so
files.
Note: The file name of the deck should not include spaces
as they cannot be read as one line in the command prompt. If you want to
include a space between words, use the '_' symbol, such as
test_deck.dem.
