Analyze Results
The Results Analysis section of EDEM Cal combines all the results files into a single csv file.
In the EDEM Cal page, select the folder containing
distributed files and then click the ... icon.
Navigate to the folder and click Select folder.
This will populate the box with the path to the selected folder.Note: You must select the correct path to the job save location containing the files generated by EDEM Cal.
- Once the box is populated, click Generate Combined Results File.
