Working Point Test Enhancements for synchronous machines
Information
The new version, FluxMotor 2025, introduces significant improvements to the working
point test for all synchronous machines, enhancing functionality and reducing
computation time:
- New Fast Mode with rotor position dependency
- Offers faster computation than the accurate mode with comparable accuracy.
- Computes AC losses using a hybrid method.
- Optimized Thermal Solving:
- Incorporates a new backend process that doubles computation speed.
- Enables highly efficient full emag.-thermal coupling, leading to the removal of the one-way coupling option.
- Ripple Torque Analysis:
- The separate ripple torque analysis option is removed.
- Ripple torque values are now provided only in Fast Mode (with rotor position dependency) and Accurate Mode.
Working Point Test Enhancements for synchronous machines |
