Slip distribution table
When “Table” is selected, the list of slips to be considered must be defined by using the field: “Slip table” and then clicking on the button “Set values”.
Two ways are possible to fill the table: either filling the table line by line or by
            importing an excel file, where all the slips to be considered are defined.
        Note: The slips must be listed in ascending order.
| Slip distribution mode = Table | |
| 1 | Select the “Table” option. |
| 2 | Click the button “Set values” of the field “Slip table” to open a dialog box defining the list of slips to be considered. Refer to the next illustration which shows how to fill the Slip table. |
| 3 | Button to validate and consider the user inputs |
| 4 | Button to run the computation |
| Slip distribution mode = Table – Dialog box to define the list of slips | |
| 1 | Dialog box opened when clicking on the button “Set values” in the field “Slip table” |
| 2 | Browse the folder to select an Excel file which defines the list of slips |
| 3 | Button to refresh the table data when the considered Excel file has been modified |
| 4 | Fields to be filled with data to describe the considered slips |
| 5 | Button to apply the inputs |
| 6 | Button to erase the data table |
Note:
        The Excel template used to import the list of slips is stored in the folder Resource/Template in the installation folder of FluxMotor®. An example of this template is displayed below.
| Excel file template to define the list of slips |
Note:
    - The slips must be listed in ascending order.
- We recommend defining at least 100 values to get an accuracy high enough, (especially since going below 100 does not lead to a significant reduction in computation time).
