Impedance
Overview
The aim of this section is to compute the inter-bar impedance of the damper.
In the section on impedance, two solutions are proposed to compute the end-ring impedance:
  • None: Automatic mode.
  • Constant: A user mode where it is possible to set the different values of resistance and inductances.
Table 1. End-ring – Impedance – Two modes of definition are available
1 Default setting: Automatic way for computing the end-ring impedance. It is based on internal computation processes.
2 Button to select a user mode for defining the different values of resistance and inductances
Automatic
When automatic computation mode is set, inter-bar end-ring impedances are computed by internal processes, being a function of the temperature at the end-ring (at Connection Side and Opposite Connection Side), and the material of the end-ring.
Constant computation mode
When constant computation mode is set, the inter-bar end-ring resistance and inductance values must be set by the user. The values are given for a reference temperature. In this case the inter-bar end-ring resistances and inductances depend on the temperature and materials of the end-ring.
Table 2. End-ring – Constant computation mode
1 Reference temperatures for both sides of the machine
2 - 2.1 Inter-bar impedance characteristics to be defined on both sides of the machine.
3 - 3.1 Inter-pole impedance characteristics to be defined on both sides of the machine.
Note: On one pole, the distances between bars may differ from one another. In that case one only considers average value in the automatic mode as well as in user mode (Constant).
