Specific heat
Specific heat
Symbol Definition Unit
T refS Specific heat reference temperature °C
C ref Specific heat at T refS and P ref J/K/Kg
a Specific heat first order temperature coefficient at T refS and P ref (K-1) K-1
b Specific heat second order temperature coefficient at T refS and P ref (K-2) K-2
Note: All the parameters defined in the previous table are defined for the reference pressure Pref mentioned in the gas mass density section.
Note: For a given temperature, the gas specific heat (J/K/kg) changes with the pressure following the perfect gas law.
The specific heat C computed at a pressure P is computed as below:
P ref Reference pressure Pa
C P Specific heat at the pressure P J/K/Kg
C Pref Specific heat at the pressure P ref J/K/Kg
