E.Conductor
Here are the properties that can be edited in an electrical conductor:
| Label | Unit |
| Author | * |
| Manufacturer | * |
| Price | USD/kg |
| Reminder | * |
Mechanic
| Label | Unit |
| Mass density | kg/m3 |
Electric
| Label | Unit |
| Reference temperature Tref | °C |
| Isotropic resistivity at Tref. | Ohm*m |
| Temperature coefficient at Tref. | 1/K |
Thermic
| Label | Unit |
| Reference temperature (Tref) | °C |
| Isotropic thermal conductivity at reference conditions | W/K/m |
| Specific heat at reference conditions | J/K/Kg |
Note: Non-magnetic behavior.
Note: The relation between the electrical resistivity and the
temperature is described in the Advanced section: “Impact of temperature on physical
properties”.
Note: Thermic variables (thermal conductivity and specific heat)
are constant and independent of temperature. Reference temperature is given, but its
value does not affect the thermal model of the conductor.
