Solid
Here are the properties that can be edited in a solid:
Label Unit
Author *
Manufacturer *
Price USD/kg
Reminder *
Mechanic
Label Unit
Mass density kg/m3
Young’s modulus (E) N/m2
Poisson’s ratio (ν) 1
Shear modulus (G) N/m2
Electric
Label Unit
Reference temperature (Tref) °C
Isotropic resistivity at Tref. Ohm*m
Temperature coefficient at Tref. 1/K
Magnetic
Label Unit
Magnetic polarization at saturation J s T
Relative permeability 1
Knee coefficient 1
Thermic
Label Unit
Reference Temperature Tref °C
Isotropic thermal conductivity at Tref W/K/m
Specific heat at Tref J/K/Kg
Note: The B(H) curve is defined with an analytical model, as described in the Advanced section: Create a B(H) curve.
Note: Iron losses are not considered in solid materials.
Note: The relation between the electrical resistivity and the temperature is described in Advanced section: “Impact of temperature on physical properties”.
Note: The thermal conductivity of solid regions is constant, whatever the temperature of the region is.
