Script Factory
Script Factory does not stop correctly.
Script Factory does not stop correctly if FluxMotor has been killed. This occurs if the FluxMotor process has been killed externally. Then, Script Factory is not able to get back to a valid state, neither automatically nor after a kill of the process (ref.: FXM-15140).
Script Factory freezes temporarily when running a script.
When running a script, the Script Factory gives the impression of freezing (while still running in the background). The editing window of the script becomes unresponsive until the script is done executing (ref.: FXM-13138).
Testing and exporting projects should be prohibited for certain use cases.
For example, testing and exporting of projects with scripts should be prohibited when slot filling is bad, or when the End-windings X-Factor leads to negative end-windings resistance (ref.: FXM-16455).
The new files are not visible in the tree if the folder is empty.
When we open an empty directory, the workspace tree is empty. Using the ‘New file’ button does not make visible the created files. (ref.: FXM-16901).
