Induction machines – Motor Factory – Test environment
The computation of the efficiency map (U, I) with mechanical losses can fail.
This issue raises a null-pointer exception (ref.: FXM-16157).
The flux density is not displayed in accurate mode computation.
While computing a working point (U, f, N) for an induction machine with a skewed squirrel cage and outer rotor, the flux density inside the airgap is not displayed. (ref.: FXM-16154).
Error when exporting and solving a project in Flux Skew – Transient application.
This issue occurs when the user input “Represented coil conductors” is set to All phases (ref.: FXM-15877).
Scalar Maps or Efficiency map (U,f) tests fail with hairpin winding technology
Sometimes, the tests Scalar Maps and Efficiency map (U,f) are not correctly solved with a hairpin winding configuration, like for the Motor M1 of the reference catalog (ref.: FXM-15843).
Power balance of No-load working point
Sometimes, computation of the no-load working point (slip = 0.1%) leads to a NaN (Not a Number) result. The computed amount of iron losses is not consistent with the power balance (ref.: FXM-12600).
Issue while computing the of efficiency map (scalar control – U, f or U, I)
This problem occurs when there are 3 poles represented for the periodic portion of the model under consideration (ref.: FXM-17150).
Issue while computing the efficiency map (scalar control – U,f or U,I) – IMSQ
The scalar model gives wrong results when hairpin winding technology is considered compared to results obtained with an equivalent classical winding (ref.: FXM-17183).
Torque slip curve
Test results are not continuously consistent over a torque slip curve. This occurs with the test Performance mapping T(Slip) - induction machines with a skewed squirrel cage. When the user targets a working point as an added value to be computed with the whole Torque-slip curve, sometimes this additional working point doesn't belong to the curve (ref.: FXM-12599).
