Synchronous machines – Motor Factory – Test environment
In accurate mode the sign of the reactive power, and the phase angle is not right.
The sign conventions are not respected for defining the reactive power and phase angle (ref.: FXM-16143, FXM-16542).
Working point – Square wave – Forced I – Average computation of quantities.
The computation of average quantities like iron losses, the Joule losses in magnets, and torque is not executed over a full electrical period. That can lead to wrong results (ref.: FXM-14091).
Maximum speed computation
The estimation of the maximum speed is wrong for the tests “Working point - Sine wave – Motor - U-I” and “Working point - Sine wave – Motor - T-N” when the control mode MTPA is selected (ref.: FXM-10916). The computation is always performed by considering the MTPV command mode.
Difference between map and torque-speed envelop
In the efficiency map with thermal coupling and duty cycle, the base speed table + torque speed envelope don't match with the map (ref.: FXM-17188).
The Duty cycle index plot is not displayed; NaN is always displayed instead.
In the test Performance mapping-Efficiency map & Duty cycle with thermal coupling, the duty cycle index plot is not displayed: NaN is always displayed instead (ref.: FXM-17246).
Export - HyperStudy – A wrong setting for the working point (I, Ψ, N).
For SMPM and SMRSM in the export for HyperStudy, when selecting the working point I,PSI,N, while exporting the connector, the Setting “thermal iterative” is available but should not be. Note that the connector can be generated but doesn’t work (ref.: FXM-17277).
