Simplification of Objects in an Indoor Database
WallMan offers a menu item, . The Simplify Indoor Database dialog is shown in Figure 1
![](../../../../../images/winprop/user_guide/wallman_tuman/wallman_usage/dialog_simplify_indoor_database.png)
Several parameters are available to define the behaviour of this function: The Tolerance for displacement describes the maximum value for the displacement between two polygons which will be combined. A condition can be defined for cases where polygons should be combined. Further settings can be defined with the check boxes.
When using very complex vector databases, for example, models of vehicles, the simplify function may lead to problems or may need very long computation times.
