Altair WinProp  2022.3 Documentation
2022.3
  1. Home
  2. WallMan
    The WallMan component offers a convenient facility to generate and edit vector building databases.
  3. Using WallMan
  4. Database Editor
  5. Database Editing (Optional)
  • Release Notes
  • Get Started
  • Examples
  • Introduction to WinProp
  • Typical Workflow in WinProp
  • WallMan
  • TuMan
  • AMan
  • ProMan
  • Methods
  • Main Applications
  • Optimization (OptMan)
  • Connectivity Manager (CoMan)
  • WinProp Utilities
  • Appendix
Index
2022.3
  • Release Notes
  • Get Started
    The WinProp Getting Started Guide contains step-by-step instructions on how to get started with WinProp.
  • Examples
    The Altair installation directory contains a collection of examples that shows you WinProp concepts and essentials.
    WinProp is a complete suite of tools in the domain of wireless propagation and radio network planning. With applications ranging from satellite to terrestrial, from rural via urban to indoor radio links, WinProp’s innovative wave propagation models combine accuracy with short computation time.
    View the typical workflows when working with propagation simulations in specific scenarios, how to add a network planning to a propagation simulation, include a receiver pattern, set up a time-variant scenario, include multiple-input multiple-output (MIMO) at both the base station and the mobile station, connectivity analysis of sensor networks and optimization.
  • WallMan
    • Introduction to WallMan
    • Introduction to the Interface
    • Using WallMan
      • Database Editor
        • Database Creation: Indoor
        • Database Creation: Urban
        • Database Creation: Hybrid Urban / Indoor (CNP)
        • Database Creation: Topographical Database
        • Database Editing (Mandatory)
        • Database Editing (Optional)
          • Simplification of Objects in an Urban Database
          • Simplification of Objects in an Indoor Database
          • Move Objects
          • Rotate Objects
          • Triangulate Objects in an Indoor Database
            Repair or replace objects that would otherwise be considered invalid, such as non-planar ones by triangulating objects.
          • Modification of Corners of Objects
          • Renumber Objects in Database
          • Add Virtual Buildings to Urban Database
          • Combine Objects
          • Group / Ungroup Selected Objects
          • Specify Wall Type in Indoor Database
          • Add Time Variance to Objects
          • Edit Clutter Properties
          • Edit Single Wall in Indoor Database
          • Determine and Show Shape of Buildings
      • Database Pre-Processing
      • Indoor LEGO Tool
      • Miscellaneous
    • Materials
  • TuMan
    The TuMan tool enables you to generate and modify tunnel scenarios.
  • AMan
    Use AMan to generate, edit and analyze a single antenna. Superimpose multiple antennas radiating similar signals to determine the actual antenna pattern while taking into consideration the local environment.
  • ProMan
    The ProMan component includes wave propagation models for different scenarios and network planning simulators for various air interfaces.
  • Methods
    WinProp includes empirical and semi-empirical models (calibration with measurements possible), rigorous 3D ray-tracing models as well as the unique dominant path model (DPM).
  • Main Applications
    In WinProp various air interfaces and applications are pre-defined: broadcasting, cellular, wireless access, WiFi, sensor networks, ICNIRP and EM compliance.
    The OptMan component allows the automatic optimization of orientations of antennas in cellular networks to achieve various targets.
    The CoMan component allows the simulation of the reliability and connectivity in wireless mesh / sensor networks.
  • WinProp Utilities
    The WinProp utilities consist of the Launcher utility and the Updater.
  • Appendix
2022.3
  1. Home
  2. WallMan
  3. Using WallMan
  4. Database Editor
  • Release Notes
  • Get Started
  • Examples
  • WallMan
  • TuMan
  • AMan
  • ProMan
  • Methods
  • Main Applications
  • WinProp Utilities
  • Appendix
Index
  • Move Objects
  • Rotate Objects
  • Combine Objects
