Move Objects
Arbitrary objects can be moved along the x, y and z-axis. It works the same way in outdoor and indoor databases. First, the objects that should be moved must be selected. Then select
from the menu.In the appearing dialog enter the values for the vector along which the objects should be shifted. The unit of the vector is meters and negative values are allowed.
Figure 1. The Move Objects dialog.
Click OK and the selected objects are moved.
