Modification of Corners of Objects
Figure 1. Selected building in urban database with context menu.
Besides a few other information, the Object Properties dialog contains a list with all corners of the wall or building. Double-clicking an entry in the list opens a dialog which allows changing its three coordinates (x, y and z).
Figure 2. The Object Properties dialog.
Figure 3. The Enter Coordinates dialog.
There are two limitations for changes to the coordinates. In indoor databases, the corners must describe a planar flat if that is not the case all changes will be reverted. In outdoor databases, a change to the z value of a corner will change the z value of all corners. All corners of a building always have the same height.
