Indoor LEGO Tool
The WallMan Indoor Lego Feature, the supplementary Mouse
Meter
and the 3D Selection and Copy
tools provide a couple of easy to use
functions for indoor database creation. The main idea is the generation of basic wall
combinations (the so-called templates
) describing typical database elements such as
rectangular rooms, staircases and roofs. The user-friendly graphical interface offers dialog
based entry of fundamental template parameters (dimensions), post-creation editing
possibilities (moving, scaling, rotating), the definition of any combination of database walls
as a template, recombination possibilities for known templates and a program toolbar for fast
selection of the tool to be used.
The Mouse Meter
tool simplifies the adaptation of newly created template objects to
existing database objects by the indication of distance information. The measured distances
can be used as a base for the dimension dialog entries.
The 3D Selection and Copy
tool enables database creators to construct templates from
existing database objects by the specification of a rectangular area and 3rd coordinate
information. Using this tool, whole building parts can be copied and processed as templates
like mentioned above.
