Edit Single Wall in Indoor Database
If you want to edit a wall that is not parallel to one of the three predefined view planes,
you can switch to a view plane containing this wall. To do this, simply double-click on the
wall. This way you can switch to a view in which the selected wall is looked at from the top
(note: it is always being looked at the wall from the side closer to the coordinate system’s
point of origin). In this view, you can double-click an edge of the wall to look at this
edge.
Note: The edge is always viewed from outside the wall.
