Number of Received Carriers
This result map specifies the number of received carriers for each location (pixel) of the simulation area. If the same carriers are used on different sites (or transmitters) the number of received carriers might be increased (depending on the individual conditions). For example, if carrier X could be received from site/transmitter A and from site / transmitter B as well (and no other site / transmitter as well as no other carrier is defined in the network) the number of received carriers would be equal to two.
