Types of Results
View the available result types and the corresponding file extensions.
The section gives an overview of the available result types and the corresponding file extensions of ProMan.
| Result Type | File Extension |
| ASCII export of arbitrary result data | .txt |
| Delay spread | .fpd |
| Delay time | .fpt |
| Field strength | .fpf |
| Field strength (linear) | .fsl |
| Interactions | .fpi |
| Line-of-sight (LOS) condition | .los |
| Morpho loss | .fml |
| Path loss | .fpl |
| Power | .fpp |
| Ray data (ASCII format) | .str |
| Ray data (binary format) | .ray |
| Active set size | .ast |
| Angular spread (BS) | .asb |
| Angular spread (MS) | .asm |
| Best server | .fpb |
| Channel capacity | .cap |
| Cell area | .cid |
| Coverage | .cov |
| Channel quality indicator (CQI) | .cqi |
| Data rate (downlink) | .dda |
| Data rate (uplink) | .dua |
| Eb / No (downlink) | .ebn |
| Eb / No (uplink) | .ebu |
| Ec / Nt (downlink) | .ecd |
| Ec / Nt (uplink) | .ecu |
| Exposure | .exp |
| Exposure field strength | .fse |
| Interference | .oif |
| Interference and noise power (downlink) | .din |
| Interference and noise power (uplink) | .uin |
| LMU | .sig |
| Localization 50m | .p05 |
| Maximum field strength | .fpg |
| Maximum data rate (downlink) | .mdr |
| Maximum data rate (uplink) | .mdu |
| Maximum received downlink power | .fpm |
| Maximum throughput (downlink) | .mtd |
| Maximum throughput (uplink) | .mtu |
| MIMO streams (downlink) | .msd |
| MIMO streams (uplink) | .msu |
| Number of received carriers | .hho |
| Number of received sites | .sit |
| Number of received TRX | .fpn |
| Orthogonality | .ort |
| Power density | .pdy |
| Quality | .fpq |
| Reception probability | .rpb, .pro |
| Reference signal received power (RSRP) | .srp |
| Reference signal receive quality (RSRQ) | .srq |
| Received signal strength indication (RSSI) | .ssi |
| Rx power (BS) | .bsr |
| Rx power (MS) | .msp |
| Signal power | .spr |
| Signal-to-noise-ratio (downlink) | .snr |
| Signal-to-noise-ratio (uplink) | .snu |
| Signal-to-noise-and-interference-ratio | .fpc |
| Signal area | .sig |
| Site area | .sid |
| Soft handover | .sho |
| Spatial streams | .sps |
| Superposition field strength | .fpe |
| Superposition power | .fpa |
| Total received interference | .sin |
| Throughput (downlink) | .atd |
| Throughput (uplink) | .atu |
| Tx power (BS) | .bsp |
| Tx power (MS) | .mst |
| User distribution | .uds |
