Open
Result files can be opened with ProMan in two different ways.
First, there is the possibility to open results with the tree view on the left. All result files available for the current project are listed in this tree view and can be loaded by clicking on a tree item. The selected result will be displayed on the right side. The tree view makes it possible to access results and switch between them easily.
![](../../../../../images/winprop/user_guide/proman/results/tree_view_open_results.png)
Alternatively result files can be opened in separate result windows. Click icon. In case there is additional data
available for a result (for example, propagation paths), you can load the additional data
as well.
