Move
Move Window with Result Data
Result data can be moved within the window to get a better view. This can be done by using the scrollbars at the right and at the bottom of the window.
A further possibility is to use the move window tool. Click
and specify the distance as well as the direction of movement.![](../../../../../images/winprop/user_guide/proman/results/dialog_change_position.png)
Besides the general move window command described above, there are further options for moving the result window available in the Display menu. These options have a fixed distance increment and a fixed direction and can be reached using shortcuts.
