Configure Solution
The “Configure Solution” dialog will appear when opening SimLab, allowing users to select solutions to display in the solutions ribbon. The selected solutions will be displayed in the solution ribbon each time SimLab is launched.
If there are more than 10 solutions, we retain the existing grouping and display the corresponding solution icons in the ribbon.
For 10 or fewer solutions, all the solutions will be listed directly in the solution ribbon.
“Deselect All” / “Select All” option is used to clear the selection and to reset the solution ribbon respectively.
Set last created solution as default – This option will display the ribbons (Analysis, Mesh and Geometry) in the new database based on the last created (Active) solution.
