Open in HyperStudy
Analysis > HyperStudy > Open in HyperStudy
Open in HyperStudy
This option will launch HyperStudy to set up DOE in HyperStudy for advanced DOE and optimization study. Set the variable “SL_HST_INSTALL_PATH” to point to HyperStudy installation folder (Ex: C:\Program Files\Altair\2021.1\hwdesktop\hst\bin\win64). HyperStudy version 2021.1 or later version can be linked to set up DOE. Both the DOE using a script and using the solution can be opened in HyperStudy for setting up DOE and optimization. When HyperStudy is launched from SimLab, the same SimLab version will be set as SimLab solver script in HyperStudy.
