Replace a Flexible Body
Replace a flexible body with an OptiStruct-generated .h3d file.
All joints and motion entities attached to the flex body are preserved. This feature is similar to the flex body creation traditionally offered in Inspire, except that the flex body is created externally using OptiStruct.
  1. On the Motion ribbon, under Profile, select Analyst.
  2. Under Flex Body, select the Flex Body Replace tool.
    Tip: To find and open a tool, press Ctrl+F. For more information, see Find and Search for Tools.
    A dialog opens noting changes that will result from the Replace operation.
  3. Click Continue in the dialog.
  4. Browse and select the flex body .h3d file.
    If there are interface nodes on the flex body whose coordinate offsets are greater than what is specified in Preferences > Inspire Motion > Visualization > Flex Body Node Tolerance, a dialog opens warning of the misalignment.
    There are two options in the dialog:
    • Align – Move the motion entity attachment locations to match the locations of the interface nodes.
    • Continue – Do not move the motion entity attachment locations and accept the misalignment with the interface node.
    Note: When a part is replaced with a flexible body using the Replace option, existing Motion-Designer joint types will be automatically converted to Motion-Analyst joint types. This conversion is permanent. A part cannot be replaced with a flex body more than once. A flexible part introduced using Replace cannot be re-created using Flex Body Create.
