2026
Inspire Motion provides Multibody Simulation (MBS) capabilities to analyze the motion, dynamics, and interactions of interconnected rigid or flexible bodies within a system.
The Analyst profile functions as a feature-rich pre-processor, originally inspired by the needs of the automotive industry. Utilizing a hard-point design approach, it provides access to the full suite of MotionSolve features and capabilities. The Analyst profile offers unparalleled flexibility in system modeling and can be highly tailored to specific industry requirements. However, this versatility comes with increased complexity, requiring a higher level of MBD expertise and a specialized mindset for effective use.
Discover new features and enhancements in Inspire.
New to Inspire? Learn the basics here.
Start using Inspire with our interactive tutorials.
Create and assign variables to parametrize a model. This allows you to quickly iterate and compare design concepts by tweaking the values of the variables.
Create parametric sketches, geometry, and PolyNURBS with construction history and variables.
Create implicit models with primitives, lattices, point clouds, fields, offsetting, Booleans, inverting, smoothing, morphing, and filleting.
Set up your model and run a structural analysis or optimization.
The Designer profile adopts a user-centric approach, prioritizing accessibility and ease of use over complexity. While its feature set is less extensive than that of the Analyst profile, it compensates by streamlining functionality and abstracting complexities through intuitive user interactions. This simplicity empowers users outside the traditional Multibody Dynamics (MBD) community to achieve their objectives efficiently, requiring minimal familiarity with MBD.
General workflows to add or edit an entity in Inspire Motion Analyst.
Motion Analyst entities support expressions.
Inspire Motion supports symmetrical modeling, leveraging geometric or physical symmetry in mechanical systems to simplify both modeling and editing. Symmetrical modeling takes advantage of mirrored or repeated components, allowing systems to be represented with fewer entities and parameters.
Attachments offer a means to connect definition-based analyst entities such as systems, analyses, data sets and templates.
Define motion connections by grounding parts and creating rigid groups and joints.
Apply motors, actuators, springs, and gravity to define the elements for a motion analysis.
Convert rigid bodies or rigid groups to flexible bodies and review flexible body modes before running a motion analysis.
A Functional Mockup Unit (FMU) is an abstract representation of a dynamic system based on a tool independent standard interface called Functional Mockup Interface (FMI). An FMU enables the exchange of models from a very diverse range of domains and applications.
Define a linear, time-invariant dynamic system in the Laplace domain with a single input and output.
Define a generic dynamic system characterized by single or multiple inputs, dynamic states, and outputs.
Define a single, first-order, user-defined differential equation that entails a single dynamic state, which is integrated with the rest of the system states.
Specify a list of variables or constants that can be referenced by other entities
Use the Templates tool to create and edit blocks of text that contain data fields and programming instructions.
Run a motion analysis, plot the results, and extract the results for use in structural (FE) analysis and optimization.
Prepare and run a computational fluid dynamics simulation.
Evaluate designs by using geometric variables and applying a design-of-experiments (DOE) or optimization method. We recommend fully constraining your sketch when sketch variables are used in the design exploration.
Set up and run a basic porosity or thinning analysis.
Prepare and run an additive manufacturing simulation, and export a file for 3D printing.
Adjust the materials and environment of objects in the scene to create a photorealistic image.
Learn how to access the Inspire Python API including online help, quick start demos, and the Extension Manager.
View the glossary, frequently asked questions, and errors and alerts.
Learn keyboard shortcuts and mouse controls for common operations.
