*PART_COMPOSITE
LS-DYNA Input Interface KeywordDefines a part for composite application that contains material and ply information.
| (1) | (2) | (3) | (4) | (5) | (6) | (7) | (8) |
| *PART_COMPOSITE_{OPTION} | |||||||
| part_title | |||||||
| part_ID | ELFORM | NLOC | MAREA | ||||
If OPTION = CONTACT, insert blank line
If OPTION = LONG is not defined, insert a line
for each couple of plies
| Mat_ID1 | Thick1 | Mat_ID2 | Thick2 |
If OPTION = LONG, insert a line for each
ply
| Mat_ID1 | Thick1 |
Definition
| OPTION |
| part_title | Component title. (Character, maximum 80 characters) |
| part_ID | Part identifier.
(Integer) |
| ELFORM | Shell element formulation options.
(Integer) |
| NLOC | Reference surface location.
(Real) |
| MAREA | Added mass per unit
area. (Real) |
| Mat_ID1 | Material identifier of ply
1. (Integer) |
| Thick1 | Thickness of ply
1. (Integer) |
| Angle of ply
1. (Real) |
| Mat_ID2 | Material identifier of ply
2. (Integer) |
| Thick2 | Thickness of ply
2. (Integer) |
| Angle of ply
2. (Real) |
- This keyword maps to /PART, /PROP/TYPE51 and /ADMAS.
