*DAMPING_PART_STIFFNESS
LS-DYNA Input Interface KeywordDefines Rayleigh stiffness damping applied to a part or set of parts applied in the global coordinate system.
(1) (2) (3) (4) (5) (6) (7) (8)
PART_ID Beta
*DAMPING_PART_STIFFNESS_SET
PSID Beta
Definition
OPTION
<BLANK>
Damping is applied on a defined part.
SET
Damping is applied on a defined set of parts.
PART_ID Part identifier.
(Integer)
PSID Part set identifier.
(Integer)
Beta Stiffness damping coefficient.
(Real)
[ s ]
  1. This keyword maps to /DAMP.
