*BOUNDARY_SPC
LS-DYNA Input Interface KeywordDefine boundary conditions on nodes to fix translation and rotation.
(1) (2) (3) (4) (5) (6) (7) (8)
*BOUNDARY_SPC_OPTION1_{OPTION2}
ID Heading
NID/set_ID CID DOFX DOFY DOFZ DOFXX DOFYY DOFZZ
Definition
OPTION1 Boundary condition type. Required option.
NODE
Single node is entered as NID.
SET
Node set ID is entered in set_ID.
(Character)
OPTION2
ID
Optional flag to define an ID for the boundary condition.
(Character)
ID Optional ID.
(Integer)
Heading Boundary condition title.
(Character)
NID/set_ID Node ID or set ID.
(Integer)
CID Coordinate system identifier.
(Integer)
DOFX, DOFY, DOFZ, DOFXX, DOFYY, DOFZZ Constraint flag for the corresponding degrees of freedom:
0
Free
1
Fixed
  1. This card is mapped to /BCS card.
  2. Can not be used to constrain nodes that belong to a part with a rigid material *MAT_020.
