OS-E: 0880 Volume and Thermal Compliance Responses
Topology optimization of an aluminum heat sink with fins is be performed. The design space is modeled using first order Tetra elements.
Model Files
Before you begin, copy the file(s) used in this example to
your working directory.
Model Description
An aluminum heat sink with fins, which is modeled using solid elements and has a
convective heat source at one end and the ambient temperature is maintained zero.
Total volume responses and a thermal compliance responses were created. The
objective is to reduce the thermal compliance by changing the density of the
elements. A design constrain is defined for volume response with an upper bound
value of 93000.
- Objective
- Minimize the thermal compliance
- Constrains
- Upper bound on total volume response
- Design Variables
- Density of each element in the design space
Results
