Create and Manage Datasets
Datasets are collections of one or more simulation results used for training or testing a model.
Note: Dataset creation times vary because each solver result/input deck must be processed separately.
The following files are supported for PhysicsAI:
Table 1. List of Supported Files
Supported Solvers File Format
Abaqus .odb
AcuSolve .ensight
.h3d
ANSYS .rst
.rth
Star-CCM+ .ensight
Custom/user-generated .ensight
.unv
.h3d
Fluent .ensight
LS-DYNA .d3plot
.d3eigv
Marc .t16
Nastran .op2
.h5
.xdb
PAM-CRASH .dsy
OptiStruct .h3d
.op2
.out
.pch
Radioss .h3d
.anim
ultraFluidX .ensight
.h3d
.case
The required files based on the inputs and outputs to be used are summarized in Table 2.
Note: In Table 2, thickness and/or material is only for supported decks. See PhysicsAI-T: 3000 Custom Inputs with a Global Hook or PhysicsAI-T: 3010 Custom Inputs with a Nodal Hook for a list of supported decks.
Table 2.
Inputs Outputs Files Needed
Non-parametric Parametric Field result KPI and/or curve
Geometry Thickness and/or material Global property Nodal property
✓ x x x ✓ x Result files (.h3d, .odb, and so on)
✓ ✓ x x ✓ x Result files
Input decks (.fem, .rad, and so on) with the same name
✓ x x x x ✓ [Input deck or Result file]
.json file with the same name (outputs)
✓ ✓ x x x ✓ Input deck
✓ x ✓ x ✓ x Result file
.json with same name (inputs)
Global hooks
✓ x ✓ x x ✓ [Input decks or Result file]
.json with the same name (inputs and outputs)
Global hook
✓ x ✓ x ✓ ✓ Result file
Global hook
✓ ✓ ✓ x ✓ ✓ Input deck
Result file
Global hook
✓ ✓ ✓ ✓ ✓ ✓ Input deck
Result file
.csv file
Global hook
Nodal hook
✓ x x ✓ ✓ x Result file
.csv file
Nodal hook
✓ x x ✓ x ✓ [Input deck or Result file]
.json with the same name (outputs)
.csv file
Nodal hook
✓ x x ✓ ✓ ✓ Result file
.csv file
Nodal hook
✓ ✓ x ✓ ✓ x Input deck
Result file
.csv file
Nodal hook
✓ ✓ x ✓ x ✓ Input deck
Result file
.csv file
Nodal hook
✓ ✓ x ✓ ✓ ✓ Input deck
Result file
.csv file
Nodal hook
