Cut a Curve from an Active Window
- From the Define Curves dialog, select a curve from the Curve list or pick a curve from the active window.
                Click Cut from the curve list controls.
                The selected curve is removed from the list and is no longer displayed in the active window. The cut curve can be pasted in any HyperGraph or 3D window.
