Start HyperMesh Batch on Windows
- Launch the system command prompt and cd to the directory from which HyperMesh Batch should be run.
                At the prompt, type the full path of the HyperMesh
                    Batch executable, along with any startup options.
                At a minimum, specify the -tcl <tcl_filename> startup option. For example, <altair_home>\hm\bin\<platform>\hmbatch.exe -tcl <tcl_filename>.
