Start HyperMesh Batch on Linux
- Launch the system terminal and cd to the directory from which HyperMesh Batch should be run.
                At the prompt, type the full path of the HyperMesh
                    Batch start script, along with any startup options.
                At a minimum, specify the -tcl <tcl_filename> startup option. For example, <altair_home>/altair/scripts/hmbatch -tcl <tcl_filename>.
