Browse Results
Browse to the folder for a run that is in progress or has been completed.
Output files for a run can be monitored at any time in the simulation. This is useful when, for example, a run has failed. The individual run output files can be interrogated to try to determine the cause of the run failure.
  1. From the Design Explorer ribbon, Evaluate tool group, click the Run Status satellite icon .
    The Run Status dialog opens.
    After submitting a simulation, this dialog will open automatically.
  2. Right-click on a run that's in progress or completed and select Browse Results.
    The folder for the run in the output directory opens.
