Material Setup
The material setup section is defined within:
<MaterialSetup type="EN">
</MaterialSetup>
Table 1. <MaterialSetup> Attributes
Attribute Value Values Command
type "EN" Mandatory
The <MaterialSetup> tag is defined by:
Table 2.
Element Tag Valid Values Comment
<UserMaterialFile> Valid Material file path Optional
<EntityList> NA Mandatory Compound Element
User-Defined Material File
The user-defined materials are optional.
The user-defined materials can be added by providing a valid .csv filepath.
<UserMaterialFile>C:/Documents/Materials.csv</UserMaterialFile>
Entity List
The entity list is defined as:
<EntityList evaltype="Parts">
</EntityList>
The entity list section has the following attributes:
Attribute Valid Values Comment
evaltype "Parts" Mandatory
For Selecting Parts
</EntityList>
Entity
The entity element tag is defined as:
<entity id="1" matname="Mat_SN(1)" name="part_1” poolname="Global" FL="0"
    Findley="0.3" Kf="1" Offset="0" SE="0.3" Scale="1" TF="0">
</entity>
A valid name must be keyed in to the matname. The material name can be specified from the user-defined materials (.csv/.xml) file or from the HyperLife Material database.
Note: HyperLife evaluation will error out with a warning to log file when a user-defined material is not found in the assigned User Defined material file (.xml).
Table 3.
name Valid Part name in model file Either name or id is Mandatory. If both are given, id will be used
id Valid Part id in model file
poolname Valid poolname for the entity type
Optional
Note: If no poolname is given, default poolname of the entity will be assumed.
Scale Valid value NA
Table 4. SN Material Attributes (Valid Only for SN Analysis)
FL 0 < Value
SE 0 =< Value
Findley 0 =< Value
TF 0 =< Value
Kf 1.0 =< Value
Table 5. EN Material Attributes (Valid Only for EN Analysis)
SEe 0 =< Value
SEp 0 =< Value
Kf 1.0 =< Value
Note: The following are optional child elements of the Entity element.
Surface Finish
The Surface Finish element tag is defined as:
<SurfaceFinish Option="NONE">0.1</SurfaceFinish>
<SurfaceFinish> Option
"NONE
"POLISH"
"GROUND"
"MACHINE"
"HOTROLL"
"FORGE"
"USER"
Value 0 < Value <1.0
Surface Treatment
The Surface Treatment element tag is defined as:
<SurfaceTreatment Option="NONE">0.1</SurfaceTreatment>
<SurfaceTreatment> Option
"NONE"
"NITRIDED"
"SHOTPEEN"
"COLDROLL"
"USER"
Value 0 < Value < 2.0
Temperature Factor
The Temperature Factor element tag is defined as:
<TemperatureFactor Option="NONE"></TemperatureFactor>
There are three options available for temperature factor:
  • NONE
  • User Defined
  • FKM
Temperature factor: NONE
<TemperatureFactor> Option "NONE"
Value 0.1 (Default)
Temperature factor: USER DEFINED
<TemperatureFactor Option="USER DEFINED" Value="1"></TemperatureFactor>
<TemperatureFactor> Option "USER DEFINED"
Value 0 < Value < 1.0
Temperature factor: FKM
<TemperatureFactor Option="FKM">
    <Temperature Option="ISOTHERMAL">150</Temperature>
    <Type>FINEGRAIN STRUCTURAL STEEL</Type>
Element Tag Valid Values Valid Temperature Values
<TemperatureFactor> Option "FKM" NA
<Temperature> Option "ISOTHERMAL" NA
<Type>
"OTHER STEELS"
"GJL"
"GJS"
"GJ"
"GJM"
150 (default)
100 < Value < 500
"FINEGRAIN STRUCTURAL STEEL"
150 (default)
60 < Value < 500
"ALUMINIUM MATERIALS"
150 (default)
50 < Value < 200
