Batch Input File Format
Use the Batch Input file to run HyperLife in batch.
The HyperLife batch input XML file should be contained within the <HyperLifeInput> root tag, as shown below. The tag has two attributes: profile and version.
<HyperLifeInput profile="CrackGrowth" version="2025.0">
</HyperLifeInput>
Input files contain the following major sections:
- Preferences
- Input Files
- Model Configuration (Default)
- Material Setup
- Load Map
- Hotspot Manager
- Evaluate
