Model Configuration
Three configurations are supported:
  • • EN – Strain Life
A model configuration is defined as follows:
<ModelConfig type="EN" unit="MPa">
</ModelConfig>
Table 1. <ModelConfig> Attributes
Attribute Valid Values Comment
type EN, Mandatory
unit MPa, ksi, psi Mandatory
EN - Strain Life
Table 2.
Element Tag Valid Values
<method> Uni Axial Muli Axial
<stresscombination>
"Abs Max Principal"
"Max Principal"
"Signed von"
"Critical Plane"
"Signed Max Shear"
NA
<survivalfactor> 0 < Value < 1.0 0 < Value < 1.0
<noOfPlanes> NA 7 < Value < 93
<correction>
"GOODMAN"
"GERBER"
"GERBER2"
"SODERBERG"
"FKM"
"NONE"
NA
<sheardamage> NA
"FINDLEY"
"NONE"
<correction>
"SWT"
"MORROW"
"MORROW2"
"NONE"
NA
<tensiondamage> NA
"SWT"
"MORROW"
"NONE"
<sheardamage> NA
"FS"
"BM"
"NONE"
<plasticcorrection>
"NEUBER"
"NONE"
NA
<layer>
"Top"
"Bottom"
"Worst"
"Top"
"Bottom"
"Worst"
<typeofloading> "Time Series" "Time Series"
<resultinput>
"STRESS"
"STRAIN"
NA
