Export Batch Run
Use the Batch tool to run submission in batch.
  1. From the Evaluate tool group, click the Run Analysis tool.
    The Evaluate dialog opens.
  2. In the Evaluate dialog, click Export.
  3. On Export, a folder containing the following .xml files are created for the run at Fatigue/CrackGrowthRunHistory:
    • CG_Run.xml
    • HotSpotDetails.xml
  4. Create a batch job.
    1. From the Utilities tool group, click the Batch tool.
      Figure 3.
      The Batch Run dialog opens.
    2. In the Batch Run dialog, click and browse for the previously created CG_Run.xml file.
  5. Click Submit Run.
    A run log file (*.log) containing information about the run setup and status is written to the run folder.
  6. Analyze the log file. The log file summarizes the following details from the executed run:
    • Events created
    • Materials assigned to Hotspot
    • Evaluation time
