HotspotData
Hotspot Definition
<HotspotData>
  <HotSpot name="n_157812_HotSpot1" id="1" entitytype="node" entityid="157812">
    <CrackType dimension="2D WF">Semi-Elliptical Surface Crack</CrackType>
    <BiasEvalType Option="Meshsize">1.0000</BiasEvalType>
    <CrackDirection Option="UserDefinedSystem" SystemId="1" SystemPathName="path1" origin="157812" zaxis="228492" xzplane="157723"></CrackDirection>
    <CrackAngle>0.0000</CrackAngle>
    <CrackLengtha>0.0500 15.3454</CrackLengtha>
    <CrackLengthb>0.1000 15.3454</CrackLengthb>
    <ST>19.1817</ST>
    <MaxNoOfCycles>4000</MaxNoOfCycles>
  </HotSpot>
</HotspotData>
                <HotspotData>
  </HotSpot>
</HotspotData>
            | name | n_<node ID>_HotSpot<ID> | Name of the hotspot using Node ID and Hotspot ID |
| id | Valid Value | |
| entitytype | node | |
| entityid | Valid Value | Node ID |
<CrackType dimension="2D WF">Semi-Elliptical Surface Crack</CrackType>| CrackType dimension | 1D WF / 2D WF |
                                 One Dimensional Weighed Functions Two Dimensional Weighed Functions  |
| Crack Type | Semi-Elliptical Surface Crack | Name of the Crack used |
<BiasEvalType Option="Meshsize">1.0000</BiasEvalType>| Attribute | Valid Values | Comment |
| BiasEvalType Option="Meshsize"/ Nominal | Size / Path to Biasing TXT file |
                SystemPathName="path1" origin="157812" ="228492"
                xzplane="157723"></CrackDirection>| Attribute | Valid Values | Comment |
| CrackDirection Option="UserDefinedSystem" |
                                 SystemId SystemPathName Origin Zaxis xzplane  |
                                 Id of the system Name of the System Node ID at Origin Node ID pointing Z axis Node ID defining xz plane  |
| CrackDirection Option="Nominal" |
<CrackAngle>0.0000</CrackAngle>| Attribute | Valid Values | Comment |
| CrackAngle | Valid value | Angle for Crack plane |
<ST>19.1817</ST>
<MaxNoOfCycles>4000</MaxNoOfCycles>| Attribute | Valid Values | Comment |
| CrackLengtha | First and last dimension of crack size a | Angle for Crack plane |
| CrackLengthb | First and last dimension of crack size b | |
| ST | Valid value | Specimen thickness |
| MaxNoOfCycles | Valid value | Number of cycles to be considered for analysis. |
