Load Map
The event setup section is defined within this tag.
The load map section is defined within:
<LoadMap>
</LoadMap>
Table 1.
Element Tag Valid Values Comment
<LoadMapFile> Valid file path Applicable for LoadMap (.xml) file
<Channel> <tabfat> Mandatory
<FatigeEvents>
<Event>
<Fatload>
Mandatory
<FatigueEventGroups> <EventGroup> Mandatory , when Event groups are defined
<Fatseq>
<Fatevnt>
<Fatgrp>
<Fatevnt> - when only events are defined
<Fatgrp> - when event groups are defined
Time Series
Time Data Channels are defined as:
<Channel>
      <tabfat id="1" type="Time Data">D:/Sample_Load_path/load1.csv</tabfat>
</Channel>
Table 2. <tabfat> Attributes
Attribute Valid Values
id Valid ID
type "Time Data"
<tabfat> Valid load-history file path
Define the Event
<FatigeEvents>
   <Event Configuration="superposition" Gate="0" id="1" name="Event_1">
       <Fatload LDM="1" Offset="0" Scale="1" block="1" resultfile="" sim="" subcase="1" tabfatId="1" tabfatName=""></Fatload>
    </Event>
</FatigeEvents>
Table 3. <Event> Attributes
Attribute Valid Values Comment
Configuration "superposition" Mandatory
Gate 0 < Value < 1.0 Mandatory
id Valid ID Mandatory
name Valid name Mandatory
<Event> is defined with <Fatload>.
Table 4. <Fatload> Attributes
LDM LDM should be a non-zero value Mandatory
Offset Valid value Mandatory
Scale Scale should be a non-zero value Mandatory
block Valid value Mandatory
resultfile NA Reserved for later use
sim Valid value Mandatory when simulation list from subcase is present
subcase Valid value Mandatory
tabfatId Valid value Mandatory
tabfatName NA Reserved for later use
Without groups
    <Fatseq>
      <Fatevnt EventId="" EventName="Event_1" Repeats="1" Status="true></Fatevnt>
    </Fatseq>
With groups
    <Fatseq>
      <Fatgrp EventId="" EventName="EventGroup_1" Repeats="1" Status="true"></Fatgrp>
      <Fatgrp EventId="" EventName="EventGroup_2" Repeats="1" Status="true"></Fatgrp>
    </Fatseq>
Table 5. <Fatevnt> Attributes
EventId Valid value Either event id or name is Mandatory
EventName Event name
Repeats Valid value Mandatory
Status Valid value true/ false
