Evaluate the Model
Use the Run Analysis tool to set up and launch the evaluation.
  1. From the Evaluate tool group, click the Run Analysis tool.
    The Evaluate dialog opens.
  2. Optional: Change the name of the run.
  3. Review the selected parts, hotspot name and loadcase.
  4. Click Run.
    The status bar highlights the run progress.
    Figure 3.
  5. Optional: Click Export to export a Batch Input File.
    Note: The exported Batch input file (XML) can also be imported back into HyperLife Crack Growth session for reviewing the setup parameters. File > Import > Run Setup File.
Files created on Export:
Table 1.
File type Description
<CG_Run>.xml
<Run Name> XML file containing the CG workflow setup.
The file can be reloaded to review the CG session.
HotSpotDetails.xml XML file containing the CG hotspot parameters.
See Export Batch Run for more information on batch submission.
The following result files are saved to C:\Documents\Fatigue\CrackGrowthRunHistory by default, or the home directory defined in the preferences:
Table 2.
File Type Description
*.hlf HyperLife Session File
Details related to the fatigue setup are stored in this file. It's automatically written to the working directory upon completion of a fatigue evaluation.
  • Session file can be reloaded to:
    • Retrieve the setup
    • Rerun the retrieved setup
    • Review the calculated results
*.log HyperLife CG log file.
Highlights the run status and error log.
n_<node id>_HotSpot1.csv Crack growth results in CSV,
n_<node id>_HotSpot1_<subcase name>_<direction angle>.txt Stress Distribution of the subcase channel pair within an event for the evaluated hotspot.
n_<node ID>_HotSpot1_MaxMinStress.csv Maximum and Minimum stress across the entire stress history of the duty cycle.
n_<node id>_HotSpot1_EventSummary.csv Event summary in CSV
See Preferences for more information.
