Superconductor: models with dependence on B
Power law with dependences on B
The critical current density Jc and the exponent n are the quantities that depend on the magnetic flux density B.
The general form of the previous function is thus the following one:
(3)
where:
  • Ec is the critical electric field [V/m]
  • Jc(B) is the dependence on B of the critical current density (see below)
  • n(B) is the dependence on B of the exponent (see below)
  • ρ0 is an additional resistivity [Ω.m]
The dependence on B of the quantities Jc and n can be expressed using different models as that is presented in the tables below.
Isotropic dependence, Kim-Anderson model
2 additional parameters: BJc and Bn
Anisotropic dependence, Kim-Anderson model
4 additional parameters: BxJc ByJc and Bxn Byn
Isotropic dependence, exponential function
4 additional parameters: α β BJc and Bn
Anisotropic dependence, exponential function
8 additional parameters: αx αy βx βy BxJc ByJc and Bxn Byn
Isotropic dependence, polynomial function
2 m additional parameters: αk βk
