Search of geometric defects by type
Introduction
The checking by defect type is the operation of research and identification of the geometric defects performed on a type of defect.
Before starting
It is necessary to open the context for healing of CAD geometry as follows:
Step Action
1
Pass to the healing mode via the menu Geometry and click on Context healing of CAD geometry
→ The healing mode for geometry is activated.
Note: Click on to go back.
Search of blocking defects (1)
To search of the following blocking defects:
  • superimposed points
  • superimposed lines
  • intersection line-line
  • intersection line-face
follow the next instructions:
Step Action
1
Activate the command via the menu Healing > Search defects and click on:
  • Search intersections > Intersections line-line
  • Search intersections > Intersections line-face
  • Search superimposed > Superimposed points
  • Search superimposed > Superimposed lines
→ If the geometry presents defects of this type, the geometric defects are identified under the specific entities associated with them.
Search of blocking defects (2)
  • abnormal lines (of small dimension (Flux epsilon))
  • abnormal faces (of small dimension (Flux epsilon))
Step Action
1
  • Search abnormal entities > Abnormal lines
  • Search abnormal entities > Abnormal faces
→ A dialog box Search … is opened
Search of non-blocking defects (1)
To search of the following non-blocking defects:
  • abnormal lines (of small dimension (user epsilon))
  • abnormal faces (of small dimension (user epsilon))
Step Action
1
  • Search abnormal entities > Abnormal lines (user epsilon)
  • Search abnormal entities > Abnormal faces (user epsilon)
→ A dialog box Search … is opened.
2
Fill in the field:
  • enter the value of length / surface for the search of abnormal lines / faces
3
Validate the information:
  • click on OK
Search of non-blocking defects (2)
  • open wires
Step Action
1
Activate the command via the menuHealing > Search defects and click on Search open wires
