Creation tools: rectangle
Rectangle
Two creation mode for rectangles:
  • « Rectangle diagonale *» allows to describe graphically a rectangle by its diagonale point.
  • « Rectangle center *» allows to describe graphically a rectangle by its center point.
* The created rectangle is not an entity but merely four points and four « segment » lines.
Access / Cursor
The different accesses and personalized cursor for this mode of creation are presented in the following table:
Type Access Cursor
Rectangle
diagonale
By icon:
By menu: Construction → Rectangle → Rectangle diagonale
Rectangle
center
By icon:
By menu: Construction → Rectangle → Rectangle center
Creation Rectangle diag.
The creation process of a Rectangle diagonal is presented in the table below.
Stage Description Illustration
1 Activation of the mode
2 1 st click left : sets the first of the diagonal point of the rectangle
3
Motion of mouse :
  • gives a view of the future rectangle
  • gives data of the creation (coordinates of the future diagonal point, width and length of the rectangle)
4
2 nd click left :
  • sets the second point of the diagonal of the rectangle
  • validates the creation of the rectangle
  • creates the corresponding entities « Point » and « Line »
→ The mode is still activated and the user can continue with creating another rectangle by performing again, in the same order, the steps starting from step 2
→ The right click, permits the deactivation of the mode
Creation of Rectangle center
La procédure de création d'un ou plusieurs Rectangle centre est présentée dans le tableau ci-dessous.
2 1 st left click: fix the center of the rectangle (fictive point)
3
Moving mouse :
  • give a view of the future rectangle
  • give information of the creation (coordinates of the next point, width and length)
4
2 nd left click:
  • fix the rectangle
  • create the corresponding entities « Point » and « Line »
Information in the creation
During the creation of a rectangle, several data are available :
  • Coordinates of the point to set (position of cursor)
  • Rectangle width and length
Preview of the rectangle with information displayed during the creation
Rectangle diagonale Rectangle center
