Creation tools: polyline
Polyline
The creation mode of « Polyline » permits the user to graphically describe a segment or a sequence of segments with the associated points.
Access / Cursor
The different accesses and the personalized cursor for this mode of creation are presented in the following table:
Access Cursor
icon:
menu: Construction → Line → Polyline
Creation of polyline
The creation process of one or more polylines is presented in the table below.
Stage Description
1 Activation of the mode Polyline
2 1 st click left : sets the departure point of the first segment
3 Motion of mouse : gives a view of the future segment
4
2 nd click left : sets the arrival point of the segment
(and the departure point of a future segment if the user wants to enchain a sequence of segments)
5 Motion of mouse : gives a view of the future segment
6
3 rd click : sets the arrival point of the second segment
n-1
Click right, permits :
  • Validation of the polyline
  • Creation of the corresponding entities « Point » and « Line »
→ Note : the sketcher mode is always activated and the user can tie it to the creation of another polyline by performing again, the same steps starting from step 2
n 2 nd click right, permits the deactivation of the mode
Information of creation
During the creation of a polyline, data is available:
  • Coordinates of the point to be set (position of the cursor)
  • Length of segment being created
  • Angle between the segment being created and
    • If it is not the first: the previous segment created
    or
    • If it is the first segment : the horizontal of the first chosen point
View of the polyline with data displayed during the creation
1 st segment of the polyline 2 nd segment of the polyline
Shortcuts
In addition to the availability of magnetization common to all the creation modes (grid, vertical/horizontal directions), it is possible to have detections of the orthogonal straight lines in the polyline creation mode.
They correspond to the directions at 0° and 90° as to the previous segment.
These directions are accessible by using the SHIFT key during the creation of a polyline.
