Export data to Flux
These exports are dedicated to transfer data from a Flux project to another one, the required informations to do a data transfer are the following ones:
  • Choose the type of data to export: Static data or Dynamic data;
  • Choose the data collection to export.
The data type static allows to export the data at the current step to another Flux project. The data type dynamic allows to export a data collection over a time interval.
This data export does not properly generate a file but an object stored in the Flux database of the project that may be imported into another Flux project with the imported data collection.
Note: This export saves automatically the Flux project, in this way the created object will be stored in the internal Flux database.
Note: The location of the data (at nodes, at elements, etc.) may be directly chosen in the data collection.
