Opening import/export data context
Opening the import/export data context
The import/export data context is available:
- After solving via menu
- Before solving via menu. In this case, only supports and collections can be defined. In such case, data will be collected directly during solving process.
It is possible to limit some functionalities according to the dedicated application:
- Context dedicated to mechanical coupling
- Context dedicated to thermal coupling
- Generic context
