Cut of magnetic circuit: definition (structure)
Definition
A cut of magnetic circuit is defined by:
  • a name (and a comment)
  • a list of faces
  • an appearance (color and visibility attributes)
Name
The name to identify the entity is given by the user during creation process. A name by default is proposed by Flux: MAGNETICCIRCUITCUT_1…
A comment (optional) can be added to the name.
list of faces
A cut is constituted by a face or a group of faces cutting the closed magnetic circuit.
